1 - 1 of 1 Posts
Power WIndows not working:
So I visually quick inspected fuses 14 and 38, but did not ohm out. then pulled off kick panel to look at 30 amp current limit 2-pin block. Then I pulled out VAG COM and scanned. Still no windows working.
So I goes to the Forums. Fuse 14 stupid. I took a VOM and yep hard to see but Fuse 14 was Infiante ohms (blown). So I wasted 2-hrs, but solved the problem thanks to the Mk4-forums, It's fuse 14 stupid!
1 - 1 of 1 Posts
