Oops. I forgot. Please disregard.I posted the pressures back in post #13.
I didn't make it out. I was hearing a front end clunk whenever I went over a speed bump or loaded up the front at low speeds. I checked my LCA bushings and saw that they were completely shot.Not seeing a mk4 gti in the results...did you make it out to that event? How'd it go with the new suspension?
I'll try that at my next event: Which probably won't be for at least another month unfortunately due to my broken right foot. But that's a really good tip.when entering a turn i brake hard right before the turn then gradually let off the brakes during turn in this puts alot of the load on the front tires which helps the front grip and the rear rotate
in slaloms i stay as close to the cones as possible so i dont have to make big turns which will quickly overwhelm the fwd
Wow, stock? I don't think I can continue to run stock. It seems that I have to get hard on the brakes and for a very long time whereas other cars only need to quickly jab the brakes on the very same turn. I was told that it may be because the car is so nosy-heavy (VR6).im running stock brake setup with oreilly's 20$ pads i want to upgrade the pads but the courses we run on are sealed asphalt and is very slick as far as track surfaces go so even with my star spec tires brakes keep up with the tires grip
Have you stood on the brakes hard enough to activate ABS/lock the wheels? If not, have you had an instructor drive the car or did one ride with you during the school?It seems that I have to get hard on the brakes and for a very long time whereas other cars only need to quickly jab the brakes on the very same turn. I was told that it may be because the car is so nosy-heavy (VR6).
\X/
