Re: brake pad change question.... (mr_e1974)
Quote, originally posted by mr_e1974 » |
Coolio...thanks for the advice...I think I'm gonna try to do it Friday morning....shouldn't take too long should it? |
Well, that depends - if you are anything like me, you'll get halfway through and need to run to Sears for a tool
But if you have all the right tools, and a floor jack, you should be able to change the pads in about 2 or 3 hours (sounds high, but I think it always takes longer the first time you do something on the car). If you are changing the rotors too, tack on another hour or two.
Now that I have done it a few times, I can swap out the rear pads in about half an hour (same with the fronts) - not including the time to get the car up and the wheels off & on.
Conning a friend into helping (
is a good bribe) will cut that time down alot. Have fun
