1 - 3 of 3 Posts
Does anyone know if front dic rotors from a 92-93 passat(4 lug) are a direct fit on a '97 Gti 8v.I 've heard this is good brake upgrade if bigger rotors are desired..... Any light shed would bne great...Thanx
Re: brake swap (vwspaz)
you can use them, but i would not consider them an upgrade......
if your looking for bigger brakes g60 brakes work well for a size and caliper upgrade
if you need upgraded rears id do mk4 rears calipers with passat rear lines
or if your looking to do a full 5 lug swap you can grab the whole rear beam from a vr and for the front you grab axles out(minus struts/springs)
1 - 3 of 3 Posts
