1 - 4 of 4 Posts
I have a problem with spongy brakes, I’ve flushed the system with new fluid no change, no leaks visible. I have changed master cylinder bench bled it properly and put all new fluid and bled again, no change.
I’m going to take brakes apart this weekend re-lube all guide pins inspect pistons. If everything looks good what else can the problem be? I’m stumped
Did you bleed in order?
FL. FR. RL RR
On my car I found that the brake booster manifold vacuum line had cracked, take your off and inspect.
1 - 4 of 4 Posts
