i have a 92 Corrado with ABS and im having a problem with the brakes dragging and the pedal not coming all the way back. i have to actually pull the pedal up with my foot or the brakes will keep dragging badly. the pedal will bounce back most of the way, but stops before the last inch or so. the abs light functions properly on start-up but never comes on during driving so is it the ABS unit or is it something else ?
i had wilwood 4 piston calipers on the front, SS lines and super blue fluid.
so far i've tried:
removed wilwoods, replaced with original calipers
replaced drivers side rear caliper (thought it was sticking?)
bled the system 3 times (once with a pressure bleeder)
my thoughts are:
that maybe the passenger side rear caliper is crap and needs to be replaced? maybe it's sticking too ?
still has air in the system ????
ABS pump is broke?
ANY advice on this matter would be greatly appreciated.
so far i've tried:
my thoughts are:
ABS pump is broke?
