ok im doing the swap into my rabbit and im writing this up to make sure ive got it right.
Parts list
1. 2.0 16v 9A
2. Ecu and wiring harness
3. you can use an existing 020 tranny (i can use mine from my 1.7 rabbit)
4. Scirocco 16v exhaust manifold and downpipe
5. Scirocco intake manifold (this way you dont have to extend fuel lines)
6. Scirocco radiator
Installation
1. remove all wires from your existing engine for mine its a 1.7 so im removing all the wiring hoses and exhaust.
2. remove engine (underneath or above)
3. make sure 16v is complete and put in place of old engine it should bolt right up.
4. install exhaust manifold and downpipe
5. install new radiator and hook up hoses.
6 hook up fuel lines.
7. start wiring...... being my first engine swap im under the impression that i have to have both bentlys one for the old engine and one for the new then i match up what wires do which and connect them or replace them. i plan on using a 2.0 fusebox and looking as to what wires control dashboard functions and connect to the fuse box? not too sure here
8. start the car up
am i close?
Parts list
1. 2.0 16v 9A
Installation
8. start the car up
am i close?
