In the time that I pulled the V8 I moved shops and I also have been two other b5s in the background.
The one is my daily that I've had for almost 3 years. I originally bought from my friend after he hit a deer with it. It's a 2001 black 1.8t and 5 speed. My intent was to fix up, drive it for the rest of winter and then sell it. After a few failed attempts at selling it I just continued to keep fixing it. This thing has had a lot of work done to it and over the summer it was starting to misfire really bad every time I started it. Went through all the possible misfire fixes and finally figured it was the bottom end. My plan was to take the 1.8t out of my nice car and throw it in the daily, but it turns out that one had a huge score in one of the cylinder walls. I ended up getting a VW motor and using the 06A block with all my b5 parts. It works, but it's not exactly the same as a b5 06A.
Anyway, I'm working on finishing that up and it should be done with in the week.
(How I bought my daily)
(How it looks now)
The second one is a 2001 black 1.8t avant that I bought last year. It had a bad auto trans when I got it but everything looked fairly clean and stock when I bought it.
This car was supposed to be a quick flip and I was going to sell it to my sister to replace her 98 b5 sedan.
Instead it turned into a ****ing nightmare. In the past year I have put 3 automatic transmissions in it and finally manual swapped it over thanksgiving this year because I was fed up with putting auto trans in it.
Also after I put the first transmission in I did the timing belt and all the other normal maintenance stuff. After 100 miles the idler failed and bent all the valves in the head. Don't ever buy a timing belt kit from rock auto lol. I ended up going to the junkyard and scoring a head for $75 and slapped that boy on.
Now after the manual swap the car has been running pretty well and I've been driving it while my other two b5s are down.
(When I bought the avant)
Honestly I should have taken photos of all these projects but you live and you learn I guess.
