My key broke today and its the only one I have. I obviously will need a new key cut and programmed but the car is stuck a long way from the locksmith. The key was still able to be inserted in the ignition and I was able to barely grip the end with pliers to turn the ignition. Unfortunately, I didn't forward think to make sure the key fob with the rfid chip was near the ignition (it was on the passenger seat). Though the car started, it immediately shut down and "SAFE" was displayed near the odometer. I have tried starting it with the key fob near the ignition but the car does the same thing. I assume the immobilizer needs to be reset? How is that done? I have VagCom but the best I can tell is it is worthless for immobilizer related issues without the PIN which you have to get from the locksmith.
Thanks in advance for any help!
