1 - 13 of 13 Posts
While changing my lower control arm today, I got a nasty surprise.
The Sway bar strap that holds it to the Control arm was broken, allowing the
thing to hit the CV.
Well I ordered the strap, but the car would be out of commission until it arrives on Friday.
But after a few minutes of Fussing, cursing my bad luck I had a Eureka moment.
I tore off to the hardware store, and got a 2" center to center SS U-bolt, about the same bolt size as a 10mm bolt for the ball joint. It was about 3 inches long, so I decided to get some SS washer and a couple of lock washers.
Worked like a champ and is probably stronger than the Strap...
Well I ordered the strap for 20 bucks each, and the SS u-bolt only cost me 4.00.
Lesson learned and passed on.
'81 Trek 614, '95 Ranger
Pics or it never happened. :sly:
PICS NOW!! :mad:
Or Elses... :what:
Seriously Brian, sounds like a great fix, pics would be great!
Discussion Starter · #4 ·
PICS NOW!! :mad:
Or Elses... :what:
Why wouldn't I take a Picture of it....
Just was a tad chilled yesterday....when I was typing the thread.
Discussion Starter · #6 ·
cool.:thumbup:
Thanks, I suppose a 2" muffler clamp would work as well but I don't know if the bolt size is to big to go through the existing holes.
Just got the Car out of alignment, I replaced the control arm as well as the tie-rod.
My Ruff Guestimations on the Tie-rod were only off by 1 degree..... Hey I used a tape measure from the clip on the inner boot to the middle of the old tie-rod, then matched it to the new.....
Discussion Starter · #8 ·
Got an email from 2 different vendors for that strap, one being MK1Autohaus... They are out of stock... and as they are NLA from dealer my SS Ubolt will remain a tad longer than I wanted... but heck it is still probably stronger than the Original Strap......
Seeing if a Third vendor has it...
Discussion Starter · #11 ·
Premium Member
1993 Cabriolet
Did this setup cause the bushing to get a little wonky? I may do it just to get my car rolling again while I wait for the bracket to arrive.
Discussion Starter · #13 ·
Nope, works like a charm.
1 - 13 of 13 Posts
