So dug into my VR to do chains and went overboard, restoring/coating everything. I installed a few bits along with all new timing components and havent gotten tuned yet (would like to sort this first). I only removed VVT with the schimmel cam plates/chain tensioner because the head was decked before getting my O.K. And the chain had slack i couldnt remove with the stock actuators.
-Schrick 268/264 cams
-Schimmel Cam Plates
-Schimmel Manual Chain Tensioner
-DSG Dual Mass Flywheel
-USP HiFlow Cats/Downpipes
-Custom Magnaflow 2.5” Catback
-Ceramic Coated/Ported Exhaust Manifolds
-ECS Poly Motor Mounts
-032 Dogbone Insert
Im getting codes:
-P000A/000010 - Camshaft A (Bank 1 Intake): Positioner Slow Response
-16398/P0014/000020 - Bank 1: Camshaft B (Exhaust): Retard Setpoint not Reached (Over-Advanced)
I feel definitive hesitation on partial throttle and even getting into the kickdown switch is lack-luster. Fuel trims are within spec as well. Any one seen these codes with installing? Thanks for any leads!
-032 Dogbone Insert
Im getting codes:
