Hi guys I need to build a makeshift shed to store not so valuable things for the time being...
but I want to have it double as a slide out for my Toyota Previa van in the future.
Wondering how I should connect my aluminum pieces.
I have four extruded aluminum beams to connect vertically.
And will need to buy four 8 foot aluminum square beams to run horizontally (the black beam in the picture is for example)
Whats the best way to connect these?
I have these metal sockets... maybe i can cut them up to work as corner connectors?
Use plates as braces?
The way it would work is to lift the cage out half way through and put a wood spacer between the ceiling and cage to level it out. Ive stood on the square tubing pictured and it can hold my weight.
