bulb size for front JEtta turn signals?
629 Views 9 Replies 5 Participants Last post by  Lumalux
I searched to no avail. Anyone know what size, i want to get rid of the yellow up front. thanks!
1 - 10 of 10 Posts
Re: bulb size for front JEtta turn signals? (Mike VR6)
3457 or 3157
Re: bulb size for front JEtta turn signals? (Anand20v)
ttt....both can be used? no problems?
up
quote:[HR][/HR]ttt....both can be used? no problems?[HR][/HR]​
Yes both work.
Re: bulb size for front JEtta turn signals? (Deception)
what is the # for the sidemarker bulbs..want to switch to a whiter white bulb
Re: bulb size for front JEtta turn signals? (evanb)
quote:[HR][/HR]what is the # for the sidemarker bulbs..want to switch to a whiter white bulb[HR][/HR]​
The sidemarkers use #168 bulbs. (also known as W5W. #194 will also work)
I am talking about the factory white lights on the front corner panel not the corner bumper lights. Are they the same #?
I think you are referring to the side turn signal "repeaters". That also takes the W5W or 194 lamp. I think there is an amber lens integrated into housing so it will flash amber with a clear bulb.
For the front signals on the Jetta, you can use any of the 3000 or 4000 series wedge base lamps without the NA suffix (for a clear lamp). This includes 3057, 3157, 3357, 3457 (stock on the Jetta), and the newer 4000's which are extended service.
Be sure to replace in pairs with the same bulb to maintain balance.
1 - 10 of 10 Posts
