Hi Community,
I have an 04 Audi A4 3.0 Quattro with 128,779 miles that's got at least one issue I can't really figure out. It burns quite a bit of oil and when I start the car, a good amount of white smoke comes from the exhaust. I don't see anymore smoke until again after about 10-15 mins of driving. I bought the car from someone who had it sitting for a year so I've tried to burn through all the old gas by driving near empty a few times which may or may not have caused some of the below codes. I also see some smoke on the driver side of the motor but can't really see where exactly its coming from. Also, my oil filler cap looks a bit milky. The car does not lose coolant nor have I seen it overheat. I've heard this could all be due to a failing PCV valve. Also, I'm guessing I've got a leaking valve cover gasket. Before I start ordering parts and replacing them, would these be the correct places to start? Here's the VCDS scan:
Code:
Sunday,16,August,2020,15:05:33:58921
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: REDACTED License Plate:
Mileage: 207250km-128779mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: REDACTED Mileage: 207250km-128779miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 L HW: 8E0 909 059
Component: 3.0L V6/5V G 0010
Coding: 0016711
Shop #: WSC 63351 000 00000
VCID: 3E25C0576C69D76B617-5160
10 Faults Found:
17947 - Clutch Pedal Switch (F36)
P1539 - 004 - Implausible Signal - MIL ON
16705 - Engine Speed Sensor (G28)
P0321 - 002 - Implausible Signal - Intermittent
17468 - Bank2; Exhaust Cam Adjustment Circuit
P1060 - 004 - Open Circuit - Intermittent
17465 - Bank1; Exhaust Cam Adjustment Circuit
P1057 - 004 - Open Circuit - Intermittent
18011 - Internal Control Module
P1603 - 008 - Failed Self-Test - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
16688 - Cylinder 4
P0304 - 001 - Misfire Detected
16689 - Cylinder 5
P0305 - 001 - Misfire Detected - Intermittent
17537 - Fuel Trim; Bank 2 (Mult)
P1129 - 002 - System too Rich - Intermittent - MIL ON
17535 - Fuel Trim; Bank 1 (Mult)
P1127 - 002 - System too Rich - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels:
Part No: 8E0 614 517 A
VCID: 2615083791F96FAB097-51F2
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
VCID: 63935123A24BDA832E9-5160
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
VCID: 3537DF7B5C5F1433B0D-4B00
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 A
Component: SDAR XM 0010
VCID: 270B053396C376A3321-5042
1 Fault Found:
02635 - Tuner Not Enabled/Activated
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 3000
Coding: 0010607
VCID: 372BD5734353E623A21-5184
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 63351
VCID: 3E25C0576969D76B617-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03200
Shop #: WSC 08102
VCID: 323DE467AD31030B95F-5184
WAULT68E04A027722 AUZ6Z0C0161327
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
VCID: 71BF2B6B68877813AC5-4B3C
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
VCID: 72BD24676DB1430B55F-4B00
Subsystem 1 - Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0003
Component: Tõrsteuer.HL BRM 0003
2 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
01561 - Rear left door
59-00 - Can't Unlock
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 045172BF47357DBB773-4B5C
2 Faults Found:
00774 - Level Control System Sensor; Rear Left (G76)
28-10 - Short to Plus - Intermittent
00776 - Level Control System Sensor; Left Front (G78)
28-00 - Short to Plus
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0260
Coding: 01205
Shop #: WSC 07936
VCID: 2C01FA1F8F2555FBDF3-5042
End----------(Elapsed Time: 05:21, VBatt start/end: 14.0V/13.5V)-----------
