1 - 9 of 9 Posts
Just a quick question, how much oil is too much to be losing over time? A friend of mine is looking at a Rado, and the owner says it loses 1qt every 1000 miles. I didn't know what to tell him because mine doesn't lose any between oil changes, never had a problem with it. Thanx
Discussion Starter · #4 ·
Re: Burning oil?? (markymark420)
Any way to check if it's a ring? It seems like it would be blowing smoke if that were the case
Modified by easilyamused at 8:29 AM 2-17-2004
Re: Burning oil?? (easilyamused)
Compression test might tell ya, you could also pull plugs and look at the top of the piston for caked oil.
Which engine is it?
If it's a g60, it could have blown charger seals, spitting oil into the intake.
-Nate
mine has a problem with eating oil 2 i was told it is some what normal.......
i was like...."what do you mean normal?"
i don't know......i have a brand new bottom end.....so i don't think its rings
1 - 9 of 9 Posts
