(Edit). I think I might have found the issue to the problem I explained below. The 4 speed uses a different ball socket bushing than the 5 speed. 5speed uses 803 711 279 (which is what I have and is available from VW). The 4 speed uses 803 711 279 E which I can't find anywhere. Please let me know if this is the case and if you know where to get one. more in this old thread: Shifter bushing madness part 2
I cannot seem to get a bushing into a support rod within the 4-speed shift linkage. If anybody knows why or has a trick, please let me know.
Here's the pieces in question (the red is a bit of grease).
The inside diameter of the rod is ~1/2in The exterior of the poly bushing is ~3/4 inch. Ack.
If you look at this diagram, we are looking at parts #24A and #36:
#24A is VW part #811-711-279. I ordered a replacement piece you see the pics.
#36 appears to be VW assembly #811711803A It came with the fox.
How the heck to I get this in? It seems entirely too big. The part numbers all seem to match up. Is it the wrong part? Maybe a 4speed vs. 5speed parts issue? Thanks in advance for any insight or advice.
Phacedown.
1989 Volkswagen Fox 1.8L KE-Jetronic Shift mechanism
Diagram of OEM Shift mechanism. Contains Boot for Shift mechanism. Fits 1989 Volkswagen Fox 1.8L KE-Jetronic.
www.jimellisvwparts.com
Volkswagen Shift mechanism
Diagram of OEM Shift mechanism. Contains Adapter for gearshift mechanism. GEAR SHIFT for Shift mechanism. Fits Volkswagen.
Phacedown.
