1 - 15 of 15 Posts
Those both say 2.0T and don't list 1.8T anywhere :what:
But NO on both because they have MAF sensor housings and the 1.8T doesn't run a MAF sensor....you'd need a block off plate if you were really hell bent on buying it though. The routing should be close, but I can't confirm and wouldn't have the little nipple for the air adapter.
You need to know if you have the SAI pump and require the mini filter though first.
Unitronic makes one:
https://www.moddedeuros.com/products/unitronic-18-20-tsi-gen3-cold-air-intake-system
As does CTS Turbo:
https://www.moddedeuros.com/products/cts-turbo-air-intake-system-mk6-jetta-gli-ea888-dot-3
As does Neuspeed:
https://www.moddedeuros.com/products/neuspeed-p-flo-intake-kit-black-1-8t-2-0t-gen3-wo-air-pump
And APR's Carbonio will fit with the adapter ring:
http://forums.vwvortex.com/showthread.php?7317897-FS-APR-1-8T-Intake-Adapter-and-SAI-Mini-Filter
https://www.moddedeuros.com/products/apr-carbonio-1-8t-2-0t-cai-system-a3-gti-jetta
1 - 15 of 15 Posts
