After finally receiving my 2002 Bentley CD I have confirmed what may be ANOTHER screw up by VW on 2002 models, this time just on the AWP 1.8T.
Many of you may now know me from the 2002 Monsoon HU fix, bit it seems as though VW may have forgotten to turn ON our VARIABLE CAM TIMING
I ran a few tests with my VAG-COM when I was stock, and a lot since I have been chipped, and it doesn't activate whilst driving. It should turn on under high load up to about 4000rpm or so.
If you have a VAG-COM measure block 091. The last column is the degrees of adjustment and it should go to between 16-25 degrees. Mine never moves.
There is also another usage of the Variable Cam at cold start to improve emissions (block 094) and mine DOES work there
Anyway, what I'm saying is that there is a chance they may have screwed up the programming so if you have an AWP (or even a AWW) get someone to check block 091 as you may not be working properly.
FYI here are the exact works from the VW Service Manual:-
"There are only two positions for the adjustable camshaft, the normal position and the switched position. To bring the camshaft into the switched position, accelerate the vehicle in 1st gear from rest. Display zone 4 shows the actual position of the adjustable camshaft. If the activation of the adjustable camshaft is active - see display zone 3- it can be seen in display zone 4 whether in fact an adjustment of the camshaft has occurred (feed-back information). Camshaft in normal position = -3.0 to +6.0 CA. Camshaft in switched position = 16.0 to 25.0 CA
Post your findings
Post your findings
