Cam suggestion?
698 Views 3 Replies 3 Participants Last post by  Fast2.0L
I need a good cam! Any suggestions? I autocross and need the low/mid range power.
See less See more
1 - 4 of 4 Posts
Re: Cam suggestion? (shaolinmastr)
Neuspeed 256 is probably the best since it's the only one that won't give you a check engine light.
[Modified by Fast2.0L, 1:46 PM 11-28-2001]
[Modified by Fast2.0L, 1:49 PM 11-28-2001]
Re: Cam suggestion? (Fast2.0L)
quote:[HR][/HR]Neuspeed 256 is probably the best since it's the only one that won't give you a check engine light.[HR][/HR]​
All the other cams generate fault codes? Any ideas why? I'm working on a 2.0L swap now... I planned on a cam swap after I got it back on the street.
Re: Cam suggestion? (155VERT83)
I don't really know why bigger cams generate fault codes other than the new ECUs monitor everything and have much more precise control of things. Something like changing cams changes things outside the values the stock ECU can handle somehow. I don't really understand why, since so many people are running turbo kits on the Mk4's.
1 - 4 of 4 Posts
