Re: Camber bolts (bigger daddy)
They are very uncommon.
Be prepared to spend from 22 to 50$ (that's right) for all the bolts.
The VW kit number is 171498101A. I believe you need one kit per side.
Napa has them out of their catalogue, but you will need to order them.
Don't know what the VW dealer charges for them. Then there are online sources. You can google the part number.
If the bottom bolt is stripped, you can order that in a hard 10.6 metric fine thread from the bolt man, like Fastenall, for around .75
[email protected] The OEM nuts on top and bottom bolts are warped (staked) lock nuts, and it doesn't take long for them to ruin the threads on the bolts, if that is what your problem is.
(I am using a nylon locknut on my bottom bolts, just because I am fed up with the bolts getting stripped. I am not a big fan of staked nuts for more reasons than this. In addition, most alignment people will overtighten the nuts and strip the bolt threads that way, too.)
Hope that gets you on your way.
Modified by chickenfriend at 11:51 AM 7-7-2006
