In short, yes it can be done.
In long, maybe...
First, the 3D model needs to be solid, to give the printer something to print. Most of the models available for purchase online at places like Turbosquid.com, Squir3d.com, CGTrader.com etc. are surfaces with zero thickness, thus they cannot be printed. The geometry really needs to be created, or adjusted, by a modeler who knows what they're doing and know the requirements for 3D printing.
Second, for the detail required to make a 1/43 car look acceptable you're going to need a machine with a very high resolution. The typical maker-bot stuff that most hobbyists use aren't typically up to the task. There are shops out there that you can contract prints through, typically your best option for one-off stuff if you need high quality.
Third, at best you can print the main components, but if you want accurate coloring or finishes you'll need to do that yourself, and fabricate the clear bits for glass etc. Think of it as a 1/43 model kit. Yes, some printers can print in color but not generally to the degree of color variation that you find in a professionally manufactured 1/43 diecast or resin car. Same with gloss finishes. For parts you can probably salvage from a Mk2 golf things like seats, dash, wheels, etc.
Fourth, are you sure that no manufacturer makes it? What model Mk2 Jetta are you looking for? I know the 4 door variants are available in both big and small bumper versions, it would probably be more cost efficient and less time consuming to buy one of these and modify it to your pleasing. Lots of guys modify 1/43 if you don't have the patience/skillset/supplies to do it yourself.
