Can a VR6 pass the sniffer with no CAT...
615 Views 4 Replies 4 Participants Last post by  SlickG60
This is a VR6 with a hollowed out CAT..the car is in PERFECT running order...mainly because in the past year I have replaced the MAF, 02, CTS, Ait temp sensor and filters...this is in MA we have the new dyno type of sniffer test...
Thanks
Steve
1 - 5 of 5 Posts
Re: Can a VR6 pass the sniffer with no CAT... (SlickG60)
If they check for NO levels at anything but idle, you'll most likely fail.
Re: Can a VR6 pass the sniffer with no CAT... (need_a_VR6)
I heard of a sneaky trick of running lots of drygas(alcohol) in the car when you bring it in for smog...just what I hear- not that I condone this act or practice it myself. Anyone else hear this?
See less See more
Those dyno test is tough. Pretty sure you won't pass w/o a cat.
Re: Can a VR6 pass the sniffer with no CAT... (green_slc)
yeah I was told I could run the tank to almost empty then add some methanol with a lil gas just so it idles right and then go for it...after the test just fill it up with gas and replace the fuel filter.
Steve
1 - 5 of 5 Posts
