1 - 20 of 33 Posts
in the ATP stg3 and 4 kits ?
I've looked on their website and emailed them. Just want to know what all comes with it.
And what fuel pump to buy to go with it.
What about the coolant lines? Do they sell those and if so, how much?
ANyone else agree that their website needs some work?
Re: Can anyone list all the components included (16vracer)
quote:[HR][/HR]ANyone else agree that their website needs some work?[HR][/HR]​
Yes, the only info on their turbo kits is on the first page and its basic info that does not even really tell you much about the kit http://****************.com/smile/emthdown.gif http://****************.com/smile/emthdown.gif
Stu
Discussion Starter · #4 ·
Re: Can anyone list all the components included (rub-a-vee-dub)
Yeah, I got that. thanks
What other parts come with stage4 vs 3 ? Does 4 include a fuel pump?
Coolant lines price?
If no pump is included, which one should be ordered?
Re: Can anyone list all the components included (Boostin20v)
Stu[HR][/HR]​
Look harder next time.
http://www.goapr.com/products/about_tvs3_bags.html
· Banned
Parts included:
MAN-TB-20V Turbo Manifold, 20V 1.8T, T3,T3/T4
T3/T4E-TURBO Turbocharger, Turbonetics Perf Hybrid T3/T4 E
TRIM-TBN-CBB-HYB Ceramic Ball Bearing trim upgrade over T3/T4 Hybrid
DP-18T-300-T3-TRAN 3 in Turbo Downpipe (SS, T304 grade, w/flex section, high-flow) 1.8T
OL-FEED-04 T3
Oil feed line kit -04 (braided steel w/fittings) A1/A2/A3/A4
OL-RTN-18T-GOLF/JETTA Oil Return Line Kit - 18T, Transverse
Fl-ORL-T3/T4 Golf, Jetta, 45 deg adap, Str Adapt, 14" Oil Return flange fitting for T3
IPS-18T-T3-INLETT3 Inlet Pipe set for turbo inlet, 2.5" Silicone 90, with bent inlet pipe
MIS-HARDW-18T-T3 Hardware kit, Misc, 18T 1.8L Hardware for installation
FL-T3-DISCH-EXT Flange, T3 discharge mild steel, for external Wastegate
WG-TBN-DELTA Wastegate, external Turbonetics Deltagate (Specify 3/5/7/9 psi)
EP-MK18T-CL EPROM, MK4,18T, CL Code 2000
INJ-SET-31LB-4CYL Injector Set, Qty 4, 31LB, 4 Cylinder, G60 25% over, 2.0L Motronic 50% Over
that should be everything.... that's a painintheass to get out of Acrobat
stage IV has bigger injectors, 440cc, different software, and a boost controller, and i believe that's it.
Well, Garrett(GIAC) wrote the program to manipulate the ECU of VAg cars. He then sold the program to different companies, ATP being one of them. So , technically, it is GIAC software but it was designed by ATP for the T3T4 turbo. hopefully i got that right
Re: Can anyone list all the components included (synthsis)
quote:[HR][/HR]Well, Garrett(GIAC) wrote the program to manipulate the ECU of VAg cars. He then sold the program to different companies, ATP being one of them. So , technically, it is GIAC software but it was designed by ATP for the T3T4 turbo. hopefully i got that right
[HR][/HR]​
Close, but not quite right
GIAC has not designed any software for ATP. They may be using regular K03/K04 programs from local GIAC dealers?
Re: Can anyone list all the components included ([email protected])
GIAC has not designed any software for ATP. They may be using regular K03/K04 programs from local GIAC dealers? [HR][/HR]​
Thats what I heard too.......But I dont care..I still want the kit when I feel like it is tried and true...
Discussion Starter · #20 ·
Re: Can anyone list all the components included (drm916)
quote:[HR][/HR]
Thats what I heard too.......But I dont care..I still want the kit when I feel like it is tried and true...[HR][/HR]​
I'm haven't totally decided which kit to get. I wish more people that actually own the ATP kit would post here. I want to know what fuel pump they are using. I've started asking that in my sleep. Still no answers.
Has anyone had any ATP software problems?
1 - 20 of 33 Posts
