1 - 1 of 1 Posts
Hey Buds,
Question: Can i swap an ECU from the Junkyard (same yr,make,model) with my existing ECU?
ISSUE; My present ECU is throwing some codes and i want to see if changing it will eliminate the codes.
  • I HEARD you must re-program the ECU or 'Flash-it' to up date the firmware. NOT sure if this would create more problems than before.
  • How does one go about getting your ECU Flashed (or re-programmed) ?
Any constructive input is appreciated...Thanks!
1 - 1 of 1 Posts
