1 - 8 of 8 Posts
Customer states air bag and mil lights are on
1202 check codes codes order pcm for engine light
seat belt latch for air bag light
(they turned off the cel but airbag is still on, they had to order a part a smaller different problem, when my mom was talking to them on the phone they said something about the ecu. I was somewhere else and thinking noooo, cause of apr, but she said maybe they may have to try to reflash it, i think it still can be, can it???
and did they give me the updated window regulators?
customer states left window fell into door
cause: internal failure updated right window
install cable assembly and two clamps
Two doors
Re: Can someone answer a question about my service invoice (igotaprestent4u)
So what exactly is your question?
If it's for the airbag light, then the part then the "seatbelt" part they ordered is probably the device that your belt click into (drivers side) ... I recently had mine replaced. If it's the module, then after replacement, the fault code will be removed with the VAG-com (this may be where they used the term "flashed") If not, they might have been trying to determine if the car's been chipped. Funny thing is, I get this everytime I go to the dealer ... and I have an upgraded turbo, FMIC, Exhaust, etc. Tards.
Hope this helped.
Re: Can someone answer a question about my service invoice (PhatDub20v)
well im not sure what order pcm for cel means. and the cel came back!
and did i get the window regs. fixed with the replacements?
Quote, originally posted by igotaprestent4u »
Why don't you ask the service advisor "Does this mean that I have the new, updated window regulators?"
Discussion Starter · #6 ·
Re: Can someone answer a question about my service invoice (allstarmaterial)
i suppose i could when i go in next week, i just thought someone may know.
Two doors
Yes.
Primary Control Module for Check Engine Light.
Meaning the control module located under the dash which controls the SRS system.
1 - 8 of 8 Posts
