Re: can someone give me the codes for vag please????? (JediCorrado)
Quote, originally posted by JediCorrado » |
don't mean to dredge this up, but i had a question regarding the coding (i've searched extensively). i enabled "remote" window activation, now...how do i do it? is it like the alientech window hack on the mkiv? because in there, there was "power window close/open w/ door lock/power window switch/remote". so i only assume i can use my key remote to open them. is there a special sequence? TIA. |
VAG-COM, HEX+CAN-COM (-USB), your choice.
Access Comfort System Controller (46) - - also known as Central Covenience - - -
19 BYTE Coding follows...
(13/14 BYTE controllers are on
http://www.openOBD.org)
BYTE 06, BIT 0 set to = "0"
BYTE 06, BIT 5 set to = "0"
BYTE 07, BIT 2 set to = "1"
BYTE 07, BIT 5 set to = "1"
BYTE 08, BIT 2 set to = "1" (sunroof)
BYTE 08, BIT 5 set to = "1" (sunroof)
