1 - 9 of 9 Posts
the map of the fusebox that the bently shows does not match mine. i have fuses where there are none as well as relays.
HELP!!
Re: can someone please post a digi fusebox map? (GotEuroCorrado)
Bentley states: Fuse/Relay layout may change from vehicle to vehicle (from various years)... I had the same problem when looking for the AC relay. But, you should be able to figure it out with the help of the wiring diagram (which is accurate).
Discussion Starter · #4 ·
Re: can someone please post a digi fusebox map? (noodle32)
my fuse box is different.. on the bottom row of fuses... my last three are used and first three are not...
Modified by GotEuroCorrado at 12:58 PM 2-17-2004
what do you have a 93'? i ran into problems with bently too, mine is a 93 and it seems as if 93's were a bit different. do you have the 87-93 bentley book?
Discussion Starter · #6 ·
Re: can someone please post a digi fusebox map? (dacolino)
yea i have the 87-93 bently
if my brother hadnt lost his usb cable i would post a pic of my fusebox from my fox, its a 93' wolfie...chances are its the same thing.
Discussion Starter · #9 ·
Re: (noodle32)
i have the bently, the diagram in the bently is wrong
1 - 9 of 9 Posts
