So I had an airbag light going off on my 2017 Touareg Wolfsburg edition, code was B101713. Took the plug off that’s inside the driver door rubber piece and the wires were fine except one of the connections was loose. Wiggled the wire to check it and it popped right out, connection broke.
Question now is what size is this pin (female obviously). The part number is 7PO 937 702 if that helps. I specifically need the pin for the top left, it looks like it may be gold plated vs the others which appear just silver. Thanks all.
