Can the GIAC chip be detected by VW?
927 Views 22 Replies 16 Participants Last post by  nate1.8t
Can it be detected when I bring my car to the dealer?
1 - 20 of 23 Posts
Re: Can the GIAC chip be detected by VW? (GTI Av8tor)
Yes, all they have to do is drive it, it is pretty obvious.
Re: Can the GIAC chip be detected by VW? (nate1.8t)
Sorry, thought you had a 1.8T, you should be fine as long as you didn't throw any codes in regards to the rev limiter.
I got the socketd chip, so I can swap between stock and 1.1 bar.
Re: Can the GIAC chip be detected by VW? (krakboi)
when you switch chips, do you need that VAG COM to do it? or just PnP?
Re: Can the GIAC chip be detected by VW? (aak97)
damn it... i want a GIAC chip
quote:[HR][/HR]Sorry, thought you had a 1.8T, you should be fine as long as you didn't throw any codes in regards to the rev limiter.
[HR][/HR]​
Or just rev it past factory redline. Or look at the turbo's output (over .5 bar)
Love my EMCS. Toggle over to stock in the dealer's lot...
Forgot to mention what is now below. No matter what, nothing is invisible
[Modified by Jman5000, 4:58 AM 12-1-2001]
Re: Can the GIAC chip be detected by VW? (Jman5000)
there are no undetectable chips. period.
Re: Can the GIAC chip be detected by VW? (John A)
My dealer told me last week they cannot detect any chip. Maybe someone else knows better?
Re: Can the GIAC chip be detected by VW? (bluwlf)
they cant detect it if.
you got a separte ecu and chip it and got a vagcom to clear all the codes. make sure to switch bettween the stock and chiped ecus (and leave the chipped one at home when you go to the dealer) and dont brag about it at the dealer
Re: Can the GIAC chip be detected by VW? (awwsheeet)
anyone happen to be in the MD area and wanna delete my rev limiter codes(stock chip)?
See less See more
[HR][/HR]​
There is no turbo output on a VR6
See less See more
GIAC chips are invisible to the VAG 1552 scan tool.
However a visual inspection of an open ECU will reveal the chip
dealer service techs aren't allowed to open the ECUs though, only regional VWoA reps are. If they suspect a ECU or Chip related problem its probable the tech will call the VW rep for further investigation.
Re: Can the GIAC chip be detected by VW? (Henry)
quote:[HR][/HR]GIAC chips are invisible to the VAG 1552 scan tool.
However a visual inspection of an open ECU will reveal the chip[HR][/HR]​
not to mention a foot on the gas pedal
2
[HR][/HR]​
You still have a rev limiter and a speed limiter
See less See more
Re: Can the GIAC chip be detected by VW? ([email protected]_VVuLFzBoRg)
Look, a chipped 1.8T is going to be obvious by anyone who takes a test drive... but from where you parked it to a service bay and back, probably not. A VR6 is undetectable (except for an unlikely visual inspection) and could be taken as just a healthy motor – I've been told that some stock VR6s are rockets and others are dogs. And I've been told by SRS that the GIAC is not detectable by the VAG tool.
Re: Can the GIAC chip be detected by VW? (wumberlog)
Why does it matter? Your warrantee can not be void until you actually break the car. BTW my dealer has known about my chip since day one. They dont seem to care.
Re: Can the GIAC chip be detected by VW? (MRP2001GTi)
quote:[HR][/HR]Why does it matter? Your warrantee can not be void until you actually break the car. BTW my dealer has known about my chip since day one. They dont seem to care.[HR][/HR]​
Oh yes it does matter!
The goal here is to get warrantee work done when the car breaks even if it is chipped... not happening if the dealer knows about it.
2
Re: Can the GIAC chip be detected by VW? (Anand20v)
quote:[HR][/HR]anyone happen to be in the MD area and wanna delete my rev limiter codes(stock chip)?
[HR][/HR]​
mee tooooo
See less See more
Re: Can the GIAC chip be detected by VW? (phatplat)
[HR][/HR]​
How much power are you really generating beyond the factory limiter if your fuel maps are still stock?
See less See more
1 - 20 of 23 Posts
