Can you believe this?! (dial ups run away!)
2111 Views 51 Replies 30 Participants Last post by  eurotrash_pd
4
I just got coilovers put on, and told the place to drop it as far as it can without rubbin, and this is what they did! It looks like stock height! I have 17 inche rims on it, so tell me all u out there with 17's how far u dropped urs and could i see pix? Let me know how far u dropped it too if u could, and one last thing, i just got my headlights and grill, so thats why there isnt one in the pictures...
See less See more
1 - 20 of 52 Posts
2
Re: Can you believe this?! (gldawg240)
Doh, next time I read the whole post
[Modified by stl4310, 3:40 PM 6-4-2002]
See less See more
Re: Can you believe this?! (stl4310)
ttt
[Modified by gldawg240, 5:43 PM 6-4-2002]
Has alot to do with the rims too...What size/offset you running? Also, what size tires?
2
Holly 4x4 batman
, they screwed you on that one. slam that biatch
See less See more
Re: Can you believe this?! (98silverGTIVR6)
um i forgot what size tire and offset,
so i been tryin to get ahold of my dad to see. . .
See less See more
just slam it and if it rubs raise her up some..... http://****************.com/smile/emthup.gif
See less See more
you did say "lower" instead of "raise" right????
Re: Can you believe this?! (luigi1181)
[Modified by gldawg240, 5:54 PM 6-4-2002]
ha yeah, i think id might have fallen MAYBE a millimeter
could you post a pic of ur car blkjettavr6? so i can see ur drop?
Psst... Drop it as low as possible without rubbing? They probably assumed if you hit a bump and the tire moves you'll rub... thats why..
2
quote:[HR][/HR]um i forgot what size tire and offset,
so i been tryin to get ahold of my dad to see. . . [HR][/HR]​
Daddy, what size tires to I have?
See less See more
2
Re: Can you believe this?! (osiris)
quote:[HR][/HR]Daddy, what size tires to I have?
[HR][/HR]​
i bought the entire set of wheels with tires off of a friend, never cared to look what size tires they are, because as far as i knew, they fit, so why bother to look. Since he was probably home, id just call to have him check or tell me if he knew off the top of his head.
[Modified by gldawg240, 7:08 PM 6-4-2002]
See less See more
Front end without grille and lights looks like a Trofeo.
Re: Can you believe this?! (SabreVR6)
are u sure u bought coilover?
See less See more
Re: Can you believe this?! (passatrcr)
Time to get your jack out and go at it...
Sean
See less See more
Re: Can you believe this?! (EuroStyle)
hahaha you think thats stock height?hahaha i can stick 2 fists in my front wheel fender..look at my car(stock)...
[Modified by IIIGTIVR6, 10:22 PM 6-4-2002]
See less See more
Re: Can you believe this?! (IIIGTIVR6)
1)Go to autozone, buy a jack for $17.99 and jackstands for $24.99
2)Jack up car, place on new jackstands
3)Remove wheels
4)Adjust coils down one inch
5)Drive around for a few days, see if it rubs. If it does, roll the fenders or raise it back up. Once you get it to the height you want, have it aligned, and enjoy
Only way you can get it at the height you want is to adjust it yourself, and see what you can live with. Finding the right height is kinda tough, it'll take you 2-3 tries to get a height you want and find the limits of your car,
See less See more
Re: Can you believe this?! (Zwoobah)
sounds good i guess, y not right?
2
i have 17s and i have to tuck! i rub daily, no rolled fenders (yet) who cares! not rubbing on coils is like not busting after a lil' action
u didnt do it righthttp://****************.com/smile/emthup.gif
See less See more
1 - 20 of 52 Posts
