Re: Can you machine the disks on a 2003 A6 4.2 (cheddardip)
Not recommened to turn Audi/VW rotors. Just inspect them for grooves etc. Usually you can get away with using 2 sets of pads per set of rotors. If you are changing brake pad brand/compound, it is a good idea to rough up both sides of the rotor with sandpaper and then rinse them off to promote better pad bedding. But do not get them turned since it will make them too thin.
