Vehicle Information
- 2008 Volkswagen Golf .:R32
- 3.2 VR6
- Six speed Direct-Shift Gearbox
- Purchased from Faulkner-Ciocca Volkswagen in Allentown, Pa (27 July 2011)
- LB9A Candy White
- 128,500
- United Motorsports ECM Tune
- United Motorsports DSG Tune
- United Motorsports Spark Cut Tune
- United Motorsports Haldex tune
- DLI Teknik engine mount
- DLI Teknik transmission mount
- Fluidampr crank pulley
- VWR dogbone mount
- Integrated Engineering SAI block off kit
- OEM noise amplification pipe delete
- OEM .:R36 black ignition covers and loom
- OEM Tiguan coolant cap
- Forge Motorsports induction kit
- ECS Tuning billet aluminum dipstick
- ECS Tuning billet aluminum oil filter housing
- ECS Tuning magnetic oil drain plug
- LiquiMoly 5W40
- LiquiMoly DSG fluid
- LiquiMoly Haldex fluid
- LiquiMoly differential fluid
- Milltek Sport Free Flow Exhaust Manifolds
- Milltek Sport Downpipes
- Milltek Sport Cat Replacement Pipe (Test Pipe)
- Milltek Sport Link Pipe
- Milltek Sport Non-Resonated Cat-Back Exhaust
- OEM GTI dash trim
- OEM GTI door trim
- OEM GTI flip-up coin holder
- OEM GTI map light/sunroof control (2006 only)
- OEM aluminum glovebox handle
- OEM RNS-510 (revision P)
- OEM Dynaudio amp
- OEM 9W7 bluetooth
- OEM European light switch with front/rear fog lights
- OEM European dash cubby
- OEM European dash tray
- OEM European cup holder
- OEM European seat drawers
- OEM Manual shifter bezel and boot
- OEM .:R Monster mats
- OEM Gorilla Gear trunk mat with luggage blocks
- OEM Warning triangle
- OEM Transboard Tray
- OEM door warning lights (PerformanceLEDs bulbs)
- Double Apex USB Charger
- Double Apex aux-in (in front of shifter)
- Double Apex garage door opener
- OEM .:R36 dead pedal
- VWVenison black hazard switch cover
- ECS Tuning smooth beauty bezels
- Creations Motorsport .:R Alloy seat handle inserts
- EuroSport rear upper stress bar
- S2T aluminum paddle shifters - silver anodized
- OEM .:R valve stem caps
- OEM .:R32 license plate frame
- OEM Passat mirror caps
- OEM rear view camera
- OEM base carrier bars
- Thule Canyon 859 roof basket (shared between my Alltrack)
- Konzept Automobiltechnik European .:R32 front bumper
- Color matched rear reflectors
- ECS Tuning hatch pop kit
- Opti-Coat Pro+ ceramic coating
- Opti-Glass Pro ceramic coating
- GTI projector fogs
- Hella 9006 yellow fog light bulbs
- SRS-Tec fog light grilles
- Lamin-X clear head lamp film
- Lamin-X clear fog lamp film
- PerformanceLEDs interior kit (6,000k)
- in.pro smoked mirror turn signals
- in.pro European LED Taillights with rear fog
- Ziza pure yellow flash-to-pass bulbs (H7)
- PerformanceLEDs license plate bulbs (Elite housings/bulb)
- PerformanceLEDs stage V city light bulbs
- PerformanceLEDs side marker bulbs (in engine bay)
- PerformanceLEDs reverse bulb
- PerformanceLEDs rear fog bulb
- Air Lift Auto Pilot v2 management
- Air Lift Performance air struts
- Air Lift double bellow air springs
- Bilstein Sport shocks
- Air Zenith OB2 compressor
- 3/8" lines
- 5 gallon tank
- Powerflex Race (black) front control arm bushings (forward and rearward)
- Powerflex Race (black) pendulum mount bushing
- H&R 24mm adjustable front sway bar
- H&R 26mm adjustable rear sway bar
- Neuspeed rear endlinks
- TyrolSport front dead set kit
- TyrolSport rear dead set kit
- BBS CO; 18" x 8", ET44
- OEM Interlago replicas; 18" x 8", ET45
- Nitto NT555 G2, 225/40R18 92W
- Nitto Motivo, 235/40ZR18 95W
- Apex Competition Systems 65mm race studs | M14 x 1.5
- Apex Competition Systems R14 ball seat nuts | M14 x 1.5
- EBC Redstuff brake pads
- Adams Rotors high carbon iron dimpled brake rotors
- Tyrolsport front brake caliper stiffening kit
- USP Motorsports stainless steel brake lines
- LiquiMoly racing brake fluid
- Remote windows open/close enabled
- Great Britain Instruments (flash to pass on as high beams)
- Disabled DRL
- Unlock all doors with one touch
- Hatch open via remote enabled
- Hazards with hard braking enabled
- Amber LED tail lamp turn signals
- Rear fog light enabled
- Front fog lights enabled
- Connecticut
- Delaware
- Maryland
- New York
- New Jersey
- North Carolina
- Pennsylvania
- Tennessee
- Virginia
- West Virginia
- VW Fest 8 - First Place [Watercooled class]
