1 - 7 of 7 Posts
Hello Dana,
I have searched for a fix/work-around for this issue without success. A couple suggestions include having the doors unlocked from inside the car; however I still get the error msg "Cannot communicate with controller" when I select the module. What else can I try? Also, I DO NOT see the module listed in an auto-scan:
Code:
VCDS Version: Release 11.11.2
Data version: 20120126
Saturday,25,February,2012,13:03:20:49820
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
          75 76 77
VIN: WAUVT64B24N089300
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 R    HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0020
   Coding: 0016752
   Shop #: WSC 02334 785 00200
   VCID: 448DB2C00480FE3
1 Fault Found:
18339 - Coolant Fan Control Module (J293)
            P1931 - 002 - Malfunction - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4B0 927 156 FF
   Component: AG5 01V 3.0l5V  USA 1213
   Coding: 0001002
   VCID: 70E52E1060B8323
No fault code found.
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 H
   Component: ABS/ESP allrad      3428
   Coding: 06497
   Shop #: WSC 02334
   VCID: 26490848C2FC2C3
Address 15: Airbags        Labels: None
   Part No: 4B0 959 655 AB
   Component: Airbag 8.4EP        1001
   Coding: 0000607
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01002
   Shop #: WSC 02334
   VCID: 2F67ED6CED066DB
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 983 E
   Component: KOMBI+WEGFAHRS. VDO D16
   Coding: 16262
   Shop #: WSC 03285
   VCID: 2A51FC78D6E4083
   WAUVT64B24N089300     AUZ7Z0D2601657
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D38
   Coding: 15885
   Shop #: WSC 02334
   VCID: 336FE11C012E49B
Address 36: Seat Mem. Drvr        Labels: None
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0204
   Coding: 00001
   Shop #: WSC 00000
   VCID: 2C5DFA60DC10163
Address 55: Xenon Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00050
   Shop #: WSC 02334
   VCID: 040D72C014003E3
2 Faults Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
            30-00 - Open or Short to Plus
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
   Part No: 4B0 035 195 N
   Component: symphony II NP2    0410
   Coding: 02005
   Shop #: WSC 73472
   VCID: 2B5FF97CD91E11B
End   ---------------------------------------------------------------------
Oh, I wasn't aware of that other than the CAN BUS limitations. Thanks Uwe. So, how does one tweak settings like fogs as DRL, etc. Does an ECM firmware upgrade help?
Thanks.
Sent from my PG86100 using Tapatalk
Thanks.
Those components are not controlled via any control module, so it can not be done with VCDS.
Perhaps you misunderstood me / my question. How else do you modify (via long coding) settings. I am aware, with the module available in your vehicle , you can do that via VCDS.
Discussion Starter · #7 · (Edited)
You can not do it with VCDS,it is not possible on that car.
Only way to do this is to run 12V to fog lights form DRL .
.....or rewire fuse #36 (for fogs) to a "switched source /fuse" e.g. fuse #27 (rear wiper/heated steering in the A6) so it is independent of the low beams . I have seen a couple DIYs for this (though it won't work for an Avant - for obvious reasons). Thanks.
1 - 7 of 7 Posts
