1 - 7 of 7 Posts
Okay. I have a spacer on my rear O2 sensor. I am thinking either it's not getting enough of a reading or too much of a reading. The rear O2 sensor is new and the wires and connections all seem in very good condition. I even had this code with the previous O2 sensor. So I can assume that the O2 sensor was never to blame. Below is my auto log and I also logged groups 30 and 36.
Monday,27,November,2006,12:06:43
VAG-COM Version: Release 607.3-UD
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN Number: 9BWKE61J434056370
Address 01: Engine
Part No: 06A 906 032 PL
Component: 1.8L R4/5VT G 0003
Coding: 07510
Shop #: WSC 00001
9BWKE61J434056370 VWZ7Z0C6709661
1 Fault Found:
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
Readiness: 0000 0001
Address 03: ABS Brakes
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001
No fault code found.
Address 15: Airbags
Part No: 1C0 909 605 F
Component: 0S AIRBAG VW61 0108 0001
Coding: 12371
Shop #: WSC 00001
Address 17: Instruments
Part No: 1J6 920 906
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 07234
Shop #: WSC 00001
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00001
1 Fault Found:
01304 - Radio
End --------------------------------------------------------------------------------------------------
Monday,27,November,2006,11:47:50
06A 906 032 PL,,1.8L R4/5VT G 0003,
,Group A:,'030,,,,Group B:,'036,,,,Group C:, Not Running
,,Bank 1,Bank 1,Bin. Bits,Bin. Bits,,Bank 1 Sensor 2,Result,Bin. Bits,Bin. Bits,,,,,
,TIME,Sensor 1,Sensor 2,,,TIME,Voltage,Lambda Availability,,,TIME,,,,
Marker,STAMP,,,,,STAMP, V,,,,STAMP,,,,
,0.01, 00011, 0010, , ,0.23,0.020,Test ON, , ,,,,,
,0.54, 00111, 0110, , ,0.84,0.020,Test ON, , ,,,,,
,1.14, 00011, 0010, , ,1.44,0.020,Test ON, , ,,,,,
,1.74, 00011, 0110, , ,2.04,0.020,Test ON, , ,,,,,
,2.35, 00011, 0110, , ,2.65,0.020,Test ON, , ,,,,,
,2.95, 00111, 0010, , ,3.25,0.020,Test ON, , ,,,,,
,3.55, 00111, 0110, , ,3.85,0.020,Test ON, , ,,,,,
,4.15, 00011, 0110, , ,4.46,0.020,Test ON, , ,,,,,
,4.76, 00011, 0110, , ,5.06,0.020,Test ON, , ,,,,,
,5.36, 00011, 0110, , ,5.66,0.020,Test ON, , ,,,,,
,5.97, 00111, 0010, , ,6.27,0.020,Test ON, , ,,,,,
,6.57, 00111, 0110, , ,6.87,0.020,Test ON, , ,,,,,
,7.17, 00111, 0110, , ,7.47,0.020,Test ON, , ,,,,,
,7.78, 00011, 0110, , ,8.08,0.020,Test ON, , ,,,,,
,8.38, 00011, 0110, , ,8.68,0.020,Test ON, , ,,,,,
,9.02, 00011, 0010, , ,9.29,0.020,Test ON, , ,,,,,
,9.59, 00111, 0110, , ,9.89,0.015,Test ON, , ,,,,,
,10.19, 00111, 0110, , ,10.49,0.020,Test ON, , ,,,,,
,10.79, 00111, 0010, , ,11.10,0.020,Test ON, , ,,,,,
,11.40, 00011, 0110, , ,11.70,0.020,Test ON, , ,,,,,
,12.00, 00011, 0110, , ,12.30,0.020,Test ON, , ,,,,,
,12.60, 00011, 0110, , ,12.91,0.020,Test ON, , ,,,,,
,13.21, 00111, 0110, , ,13.51,0.020,Test ON, , ,,,,,
,13.81, 00111, 0010, , ,14.11,0.020,Test ON, , ,,,,,
,14.41, 00011, 0110, , ,14.72,0.020,Test ON, , ,,,,,
,15.02, 00011, 0110, , ,15.32,0.020,Test ON, , ,,,,,
,15.62, 00011, 0110, , ,15.92,0.020,Test ON, , ,,,,,
,16.23, 00111, 0110, , ,16.53,0.020,Test ON, , ,,,,,
,16.83, 00111, 0010, , ,17.13,0.020,Test ON, , ,,,,,
,17.43, 00111, 0110, , ,17.73,0.015,Test ON, , ,,,,,
,18.04, 00011, 0110, , ,18.34,0.015,Test ON, , ,,,,,
,18.64, 00011, 0010, , ,18.94,0.020,Test ON, , ,,,,,
,19.24, 00011, 0110, , ,19.54,0.020,Test ON, , ,,,,,
,19.85, 00111, 0110, , ,20.15,0.020,Test ON, , ,,,,,
,20.45, 00111, 0110, , ,20.75,0.020,Test ON, , ,,,,,
,21.05, 00111, 0110, , ,21.35,0.020,Test ON, , ,,,,,
,21.66, 00011, 0010, , ,21.96,0.015,Test ON, , ,,,,,
,22.26, 00011, 0110, , ,22.56,0.015,Test ON, , ,,,,,
,22.86, 00011, 0110, , ,23.16,0.020,Test ON, , ,,,,,
,23.47, 00111, 0010, , ,23.77,0.015,Test ON, , ,,,,,
,24.07, 00111, 0110, , ,24.37,0.020,Test ON, , ,,,,,
,24.67, 00011, 0110, , ,34.13,0.020,Test ON, , ,,,,,
,34.43, 00011, 0010, , ,34.73,0.020,Test ON, , ,,,,,
,35.03, 00011, 0110, , ,35.33,0.020,Test ON, , ,,,,,
,35.64, 00011, 0110, , ,35.94,0.020,Test ON, , ,,,,,
,36.24, 00111, 0010, , ,36.54,0.020,Test ON, , ,,,,,
,36.84, 00111, 0110, , ,37.15,0.020,Test ON, , ,,,,,
,37.45, 00111, 0110, , ,37.75,0.020,Test ON, , ,,,,,
,38.05, 00011, 0010, , ,38.35,0.020,Test ON, , ,,,,,
,38.65, 00011, 0110, , ,38.96,0.020,Test ON, , ,,,,,
,39.26, 00011, 0110, , ,39.56,0.020,Test ON, , ,,,,,
,39.86, 00111, 0010, , ,40.16,0.020,Test ON, , ,,,,,
,40.46, 00111, 0110, , ,40.77,0.020,Test ON, , ,,,,,
,41.07, 00011, 0110, , ,41.37,0.020,Test ON, , ,,,,,
,41.67, 00011, 0110, , ,41.97,0.020,Test ON, , ,,,,,
,42.27, 00011, 0110, , ,42.58,0.020,Test ON, , ,,,,,
,42.88, 00111, 0010, , ,43.18,0.025,Test ON, , ,,,,,
,43.48, 00111, 0110, , ,43.78,0.025,Test ON, , ,,,,,
,44.09, 00111, 0110, , ,44.39,0.020,Test ON, , ,,,,,
,44.69, 00011, 0010, , ,44.99,0.020,Test ON, , ,,,,,
,45.29, 00011, 0110, , ,45.59,0.020,Test ON, , ,,,,,
,45.90, 00011, 0110, , ,46.20,0.020,Test ON, , ,,,,,
,46.50, 00111, 0110, , ,46.80,0.020,Test ON, , ,,,,,
,47.10, 00111, 0110, , ,47.40,0.020,Test ON, , ,,,,,
,47.71, 00111, 0110, , ,48.01,0.020,Test ON, , ,,,,,
,48.31, 00011, 0110, , ,48.61,0.020,Test ON, , ,,,,,
,48.91, 00011, 0110, , ,49.21,0.020,Test ON, , ,,,,,
,49.52, 00011, 0110, , ,49.82,0.020,Test ON, , ,,,,,
,50.12, 00111, 0010, , ,50.42,0.025,Test ON, , ,,,,,
,50.72, 00111, 0110, , ,51.02,0.025,Test ON, , ,,,,,
,51.33, 00011, 0110, , ,51.63,0.020,Test ON, , ,,,,,
,51.93, 00011, 0110, , ,52.23,0.020,Test ON, , ,,,,,
,52.53, 00011, 0110, , ,52.83,0.015,Test ON, , ,,,,,
,53.14, 00111, 0010, , ,53.44,0.015,Test ON, , ,,,,,
,53.74, 00110, 0010, , ,54.04,0.020,Test ON, , ,,,,,
,54.34, 00111, 0110, , ,54.65,0.020,Test ON, , ,,,,,
,54.95, 00011, 0110, , ,55.25,0.020,Test ON, , ,,,,,
,55.55, 00011, 0110, , ,55.85,0.015,Test ON, , ,,,,,
,56.15, 00011, 0110, , ,56.46,0.015,Test ON, , ,,,,,
,56.76, 00111, 0110, , ,57.06,0.015,Test ON, , ,,,,,
,57.36, 00111, 0010, , ,57.66,0.015,Test ON, , ,,,,,
,57.96, 00111, 0110, , ,58.27,0.020,Test ON, , ,,,,,
,58.57, 00011, 0110, , ,58.87,0.015,Test ON, , ,,,,,
,59.17, 00011, 0110, , ,59.47,0.020,Test ON, , ,,,,,
,59.77, 00011, 0110, , ,60.08,0.015,Test ON, , ,,,,,
,60.38, 00111, 0010, , ,60.68,0.015,Test ON, , ,,,,,
,60.98, 00111, 0110, , ,61.28,0.015,Test ON, , ,,,,,
,61.58, 00111, 0110, , ,61.89,0.015,Test ON, , ,,,,,
,62.19, 00011, 0010, , ,62.49,0.010,Test ON, , ,,,,,
,62.79, 00011, 0110, , ,63.09,0.015,Test ON, , ,,,,,
,63.40, 00111, 0110, , ,63.70,0.015,Test ON, , ,,,,,
,64.00, 00111, 0110, , ,64.30,0.015,Test ON, , ,,,,,
,64.60, 00111, 0110, , ,64.90,0.015,Test ON, , ,,,,,
,65.21, 00011, 0010, , ,65.51,0.015,Test ON, , ,,,,,
,65.81, 00011, 0110, , ,66.11,0.020,Test ON, , ,,,,,
,66.41, 00011, 0110, , ,66.71,0.020,Test ON, , ,,,,,
,67.02, 00111, 0010, , ,67.32,0.015,Test ON, , ,,,,,
,67.62, 00111, 0110, , ,67.92,0.020,Test ON, , ,,,,,
,68.22, 00111, 0110, , ,68.52,0.020,Test ON, , ,,,,,
,68.83, 00011, 0110, , ,69.13,0.020,Test ON, , ,,,,,
,69.43, 00010, 0110, , ,69.73,0.025,Test ON, , ,,,,,
,70.03, 00011, 0010, , ,70.34,0.025,Test ON, , ,,,,,
,70.64, 00110, 0110, , ,70.94,0.020,Test ON, , ,,,,,
,71.24, 00111, 0110, , ,71.54,0.015,Test ON, , ,,,,,
,71.84, 00111, 0010, , ,72.15,0.015,Test ON, , ,,,,,
,72.45, 00011, 0110, , ,72.75,0.020,Test ON, , ,,,,,
,73.05, 00011, 0110, , ,73.35,0.030,Test ON, , ,,,,,
,73.65, 00111, 0010, , ,73.96,0.035,Test ON, , ,,,,,
,74.26, 00111, 0110, , ,74.56,0.035,Test ON, , ,,,,,
,74.86, 00111, 0110, , ,75.16,0.035,Test ON, , ,,,,,
,75.46, 00011, 0110, , ,75.77,0.035,Test ON, , ,,,,,
,76.07, 00011, 0110, , ,76.37,0.035,Test ON, , ,,,,,
,76.67, 00011, 0010, , ,76.97,0.030,Test ON, , ,,,,,
,77.28, 00111, 0110, , ,77.58,0.020,Test ON, , ,,,,,
,77.88, 00111, 0110, , ,78.18,0.020,Test ON, , ,,,,,
,78.48, 00111, 0010, , ,78.78,0.025,Test ON, , ,,,,,
,79.09, 00011, 0110, , ,79.39,0.035,Test ON, , ,,,,,
,79.69, 00011, 0010, , ,79.99,0.035,Test ON, , ,,,,,
,80.29, 00011, 0010, , ,80.59,0.035,Test ON, , ,,,,,
,80.90, 00111, 0110, , ,81.20,0.035,Test ON, , ,,,,,
,81.50, 00111, 0110, , ,81.80,0.040,Test ON, , ,,,,,
,82.10, 00111, 0110, , ,82.40,0.045,Test ON, , ,,,,,
,82.71, 00011, 0110, , ,83.01,0.040,Test ON, , ,,,,,
,83.31, 00011, 0010, , ,83.61,0.035,Test ON, , ,,,,,
,83.91, 00111, 0110, , ,84.22,0.030,Test ON, , ,,,,,
,84.52, 00111, 0110, , ,84.82,0.025,Test ON, , ,,,,,
,85.12, 00111, 0010, , ,85.42,0.020,Test ON, , ,,,,,
,85.72, 00011, 0110, , ,86.03,0.025,Test ON, , ,,,,,
,86.34, 00011, 0110, , ,86.63,0.020,Test ON, , ,,,,,
,86.93, 00011, 0110, , ,87.23,0.025,Test ON, , ,,,,,
,87.53, 00111, 0110, , ,87.84,0.035,Test ON, , ,,,,,
,88.14, 00111, 0010, , ,88.44,0.035,Test ON, , ,,,,,
,88.74, 00111, 0110, , ,89.04,0.035,Test ON, , ,,,,,
,89.34, 00011, 0110, , ,89.65,0.035,Test ON, , ,,,,,
,89.95, 00011, 0110, , ,90.25,0.035,Test ON, , ,,,,,
,90.55, 00011, 0110, , ,90.85,0.035,Test ON, , ,,,,,
,91.15, 00111, 0010, , ,91.46,0.035,Test ON, , ,,,,,
,91.76, 00111, 0110, , ,92.06,0.035,Test ON, , ,,,,,
,92.36, 00111, 0110, , ,92.66,0.035,Test ON, , ,,,,,
,92.97, 00011, 0010, , ,93.27,0.035,Test ON, , ,,,,,
,93.57, 00011, 0110, , ,93.87,0.035,Test ON, , ,,,,,
,94.17, 00111, 0110, , ,94.47,0.030,Test ON, , ,,,,,
,94.78, 00111, 0110, , ,95.08,0.025,Test ON, , ,,,,,
,95.38, 00110, 0110, , ,95.68,0.025,Test ON, , ,,,,,
,95.98, 00010, 0010, , ,96.28,0.010,Test ON, , ,,,,,
,96.59, 00010, 0110, , ,96.89,0.000,Test ON, , ,,,,,
,97.19, 00010, 0110, , ,97.49,0.000,Test ON, , ,,,,,
,97.79, 01110, 0110, , ,98.09,0.000,Test ON, , ,,,,,
,98.40, 01110, 0110, , ,98.70,0.000,Test ON, , ,,,,,
,99.00, 01110, 0010, , ,99.30,0.000,Test ON, , ,,,,,
,99.60, 01011, 0110, , ,99.91,0.010,Test ON, , ,,,,,
,100.21, 01011, 0110, , ,100.51,0.015,Test ON, , ,,,,,
,100.81, 00011, 0010, , ,101.11,0.015,Test ON, , ,,,,,
,101.41, 00111, 0110, , ,101.72,0.025,Test ON, , ,,,,,
,102.02, 00111, 0110, , ,102.32,0.025,Test ON, , ,,,,,
,102.62, 00011, 0110, , ,102.92,0.020,Test ON, , ,,,,,
,103.22, 00010, 0110, , ,103.53,0.025,Test ON, , ,,,,,
,103.82, 00010, 0110, , ,104.13,0.030,Test ON, , ,,,,,
,104.43, 00111, 0110, , ,104.73,0.030,Test ON, , ,,,,,
,105.03, 00111, 0110, , ,105.34,0.035,Test ON, , ,,,,,
,105.64, 00111, 0110, , ,105.94,0.035,Test ON, , ,,,,,
,106.24, 00011, 0010, , ,106.54,0.035,Test ON, , ,,,,,
,106.85, 00011, 0110, , ,107.15,0.035,Test ON, , ,,,,,
,107.45, 00011, 0110, , ,107.75,0.035,Test ON, , ,,,,,
,108.05, 00111, 0010, , ,108.35,0.040,Test ON, , ,,,,,
,108.66, 00111, 0110, , ,108.96,0.035,Test ON, , ,,,,,
,109.26, 00111, 0110, , ,109.56,0.035,Test ON, , ,,,,,
,109.86, 00011, 0110, , ,110.16,0.035,Test ON, , ,,,,,
,110.47, 00011, 0110, , ,110.77,0.035,Test ON, , ,,,,,
,111.07, 00011, 0010, , ,111.37,0.045,Test ON, , ,,,,,
,111.67, 00111, 0110, , ,111.98,0.055,B1-S2 OK, , ,,,,,
,112.28, 00111, 0110, , ,112.58,0.035,B1-S2 OK, , ,,,,,
,112.88, 00110, 0010, , ,113.18,0.045,B1-S2 OK, , ,,,,,
Re: Cant seem to get rid of 17584. Logs to show. Help meh! ([email protected])
Spacer is on because I have a 2.5 ghl TB exhaust that comes with a hi-flow cat. I got the infamous cat. code a year ago. When I put the spacer on it went away. But now I have this code
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
Quote, originally posted by [email protected] »
It sounds like you'll need to either get a downpipe/cat that functions correctly ... or live with the codes.
Not what I wanted to hear
I thought so since my cat readiness test keeps failing and all my other readiness tests pass.
Andy....is there anyway to check if the cat is bad with Vag-Com? If I run groups 30 and 36 can I tell if the cat has lost efficiency?
Thanks!
Modified by Hassenpfeffer at 1:07 AM 11-28-2006
1 - 7 of 7 Posts
