Re: Capacitor to filter out high feq sound??? (Iceman666)
Have you tried swapping wires and other components around? Try moving the rca's that go to your rear amp to maybe your front amp or you subs, see if it give you noise there, if it does, you know its in that wire or something before the wire. If not, put the rca's back on that amp, and hook up a test speaker to the amp, keep the wire short, like a foot or so, if you still have noise its prolly your amp. Also, something to keep in mind, I once had bad engine noise because I had my rca's routed right next to my amps on my amp rack.
Good luck,
CS
