Re: Car almost stalling (RoccinStrybs84)
Sorry, the pic may make it look more complicated than it is.
There will be a hose running out of the valve cover and one running out of the intake manifold. They'll be connected to other lines running along the length of the valve cover....to the idle stabilizer & boost (if you have AC) switches. Those lines receive the most heat and are more likely to crap out.
Just look at each one, give them a bend and look for holes or spider cracks. If it looks questionable replace it; it's cheap & easy. I used 3/8" diameter rubber tubing and a few metal clamps that I picked up at the local auto shop.
Quick Edit: Squeezing the connections can help too. If the hose gives easy or feels soft, replace it. You might also clean the idle stabilizer valve (I've never done that, but I hear they can get sticky)
Hope this helps http://****************.com/smile/emthup.gif
Modified by FlyRoccoFly at 11:30 PM 7-19-2003
