1 - 11 of 11 Posts
This afternoon my GTI was refusing to start. The engine would turn over fine. After a few times, it finally took and started. Well it did it to me again this evening. After a few tries, it finally started. So I checked it with my VAG-COM and found these codes. Are they all related to the immobilizer? Otherwise the car has been fine with no other problems. I'm going to try my other key to see if that helps. I've cleared the codes to see if they return.
Address 01: Engine Labels: None
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17633 - Fuel Injector for Cylinder 1 (N30): Short to Ground
P1225 - 35-10 - - - Intermittent
17635 - Fuel Injector for Cylinder 3 (N32): Short to Ground
P1227 - 35-10 - - - Intermittent
17636 - Fuel Injector for Cylinder 4 (N33): Short to Ground
P1228 - 35-10 - - - Intermittent
17634 - Fuel Injector for Cylinder 2 (N31): Short to Ground
P1226 - 35-10 - - - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-10 - - - Intermittent
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-10 - - - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-10 - - - Intermittent
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-10 - - - Intermittent
17938 - Camshaft Timing Adjustment: Short to Ground
P1530 - 35-10 - - - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-10 - - - Intermittent
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-10 - - - Intermittent
Address 46: Central Conv. Labels: 1C0-959-799.LBL
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
Discussion Starter · #7 ·
Re: (CHRISWEARSNOPANTS)
Thanks for the tip and quick response! I'll keep an eye on the fuel pump relay. Time to dig out the Bentley manual again.
Re: (sfajk1)
Quote, originally posted by sfajk1 »
easy fix the fuel pump relay powers all of them short to ground thingers
Correct-a-mondo!
Remove the fuel pump relay (#409) and clean the terminal.
Otherwise replace the relay.
- Erik
1 - 11 of 11 Posts
