Re: Car won't start, Help! Tried everything. Supply some expertise here! (adias14)
As for the reasons it may not start, have you recently messed with the fueling system? When I took mine all apart, it failed to start when I got it back together. The solution was to set all the air box variables as close to spec as possible and have a friend rotate the mixture screw as I was cranking it. Eventually we hit a point where it fired up.
As for the fuel smell, you probably have a nice pool of unburned fuel in your cat by now. Expect a nice cloud of black smoke and a glowing cat when you do get it started.
quote:[HR][/HR]
The car is cranking but not turning over.
[HR][/HR]
This is impossible, if the starter pinion engages the flywheel and the motor cranks, then the engine is turning over.The car is cranking but not turning over.
[HR][/HR]
