Quick rundown of what I have going on before my question:
I am converting my mk3 aba to r1 bike carbs. Ive acquired just about all I need component wise, and started getting my lines routed and all that jazz. Since I’m using carbs ill be running a carter low PSI pump and FPR. As such, I wont be needing the in tank pump considering the PSI range it users. It will need removed. Ive replaced many mk3 pumps so I’m already half dove in...
My question is, what is everyone doing once the pumps removed? Just run a bit of line down to the bottom of the tank? If that’s the case, is there an aftermarket fuel sock you’ve placed over the fuel line inlet? I’m honestly sorta stumped about what to do here...
