1 - 4 of 4 Posts
I wanna know if there are going to be any problems if I remove my cat off my 1990 G60? I see a sensor on the top of the cat, but I am not sure what it is. I found out that my carbon build up was because of my cat though. So I was just wondering if there were going to be any complications. Also if someone could let me know real quick where to find my temp sensor. Thanx.
Re: Cat Question (GZDCorrado)
quote:[HR][/HR]I wanna know if there are going to be any problems if I remove my cat off my 1990 G60? I see a sensor on the top of the cat, but I am not sure what it is. I found out that my carbon build up was because of my cat though. So I was just wondering if there were going to be any complications. Also if someone could let me know real quick where to find my temp sensor. Thanx.[HR][/HR]​
If you remove the cat, the car will be much louder, but unless you have a full exhaust, it should still be driveable, but louder. Keep in mind, that this is completely illegal and you can get fined very heavily. Doubtful that your car will pass inspection. But I guess it depends on where you live.
When I removed my cat, I did gain some performance in the mid-to-high rpm range. The engine just breathes better, but my new G60 has a cat, and I don't plan on removing it.
That sensor, is the O2 sensor. You absolutely need it. So if you take out the cat, you need to replace it with a "test pipe" that has a flange for that sensor.
You have two temp sensors, in the flange that sticks out from the head. One blue, One black. The blue is for the ECU, and the black is for the guage inside the car.
Hope this helps...
Gary
Re: Cat Question (Kokino)
[HR][/HR]​
And a oil temp sensor on the top of the oil filter housing.
i gutted my cat after it went bad. been driving like that for a month. the rado sounds like ass and i lost a lot of low end power.....i will be ordering the tt hiflow cat next week along with a new exhaust.
1 - 4 of 4 Posts
