1 - 15 of 15 Posts
my comverter its going bad and i need to replace it how much and where can it find a cheaper one? im talking about a 1992 passat or for better solutions should i straight pipe it all the way ( including straight muffler) it this good on the car, would it have enough back pressure to run and not to burn the valves?
Re: catalityc converter how much ? (VWzealot)
I've been screaming this for years
http://198.63.20.99/WebCatalog/Call...cart=309600408617135&searchTitle=Engine Parts
Scroll about 1/2 way down and look for the only part number with VW in it. I have picked up three of these and have been happy with the results each time. The description has changed, but these were used on the Mid 80's Callaway projects cars, and outflow anything I have ever seen, including the TT stuff. Plus, they're $40.
2022 Ford Mustang Mach-E, 2021 Ford Bronco, 2003 Porsche 911 C4S, 1982 VW Rabbit
Re: catalityc converter how much ? (Patrick Schmidt)
is that the correct size for the stock downpipe? wow, that's a steal. thanks for the info man, i'm really looking into this thing. now all i need is a darn fuel pump, tires, AND a catalytic converter. no one ever said dub's were cheap...
Re: catalityc converter how much ? (P-Dub)
Sorry to take so long to get back to you guys.
The catalytic converter from Callaway has a three bolt flange at both ends, kind of like the test pipe for the MK1. I'm not sure if this is a direct bolt in replacement for 16V's, but it worked with my MK1 GTi when it was stock. Now that I have a 16V in there, I had to switch some things around, and I'm back to using the stock 16V cat. I wish I knew if this would fit or not, but I have only owned one car that came with a 16V from the factory, and that one has no cat now.
If you compare the two pieces; Callaway and TT side by side, you can see the difference in design. Callaway uses a fine mesh for the internals, while, if my my memory is correct, TT uses something similar to the factory design.
Cheers,
Pat
if the callaway one has a 3 flange on both sides its not going to work unless you cut the flange off one side and add straight pipe to it, or add a 3 flange to the existing exhaust. that price for the callaway and if it flows better might be worth the trouble. i personally hate working on the exhaust and try to stay away from that custom stuff.
do you know if the outer dimensions are the same, as in the length and height? i'm more concerned with whether or not it will physically fit under the car.
So, I'm thinking of ordering a TT cat-back this week. Will the Callaway bolt up to the TT setup or not? Its on a 2.0l 16v, (1990) so its a 50mm cat on there right now... right?
Anyone know?
quote:[HR][/HR] Scroll about 1/2 way down and look for the only part number with VW in it. I have picked up three of these and have been happy with the results each time. The description has changed, but these were used on the Mid 80's Callaway projects cars, and outflow anything I have ever seen, including the TT stuff. Plus, they're $40.[HR][/HR]​
A quick question about your flow bench. What brand is it and can you post some flow numbers? I assume you have a flow bench, or are you just assuming that the $40 cat flows better? Just curious as to how you determine that one cat was better than the other
Re: catalityc converter how much ? (GetOuttaMyWay)
no it wont "bolt right up" you would have to remove the flage , weld a pipe with a reducion in it, and figure out a way to adapt it to the down pipe flange or just buy the right cat and not worry about it
Re: catalityc converter how much ? (DrMSH)
the cat is 55mm and our stock cat is 50mm, so the callaway is larger, therefore you need some sort of reducer to make it work.
1 - 15 of 15 Posts
