don't know why, the IMG Html tag thing or function worked all night and most of today, but here be the links to the pix at villagephotos
if anyone has any insight what could have changed, i'd appreciate
first pix is of the lower half of the VW OEm airbox and the ram air horn and upper duct (the red light is simply a red LED flashlight inside to try to give the air horn some depth or whatever
http://img.villagephotos.com/p...1.jpg
next image is view from the front of the ram air horn and the upper duct joined (that brown metal object is just a weight i put there to hold the pcs upright
and in case you're wondering, the lower ram air horn outside surface isn't shiny black glossy as it didn't get a gel coat
the outside of the ram air horn is 6 oz "E" glass with the CF on the inside surface as that is what would show thru the opening on the front bumper valance
the upper duct has the "E" glass on it's inside surface
image is rotated 90 degrees counterclock wise
http://img.villagephotos.com/p...3.jpg
ram air horn + upper duct side view (from driver's side
http://img.villagephotos.com/p...2.jpg
close up view of where the upper duct joins the VW OEM lower airbox, view from the front
http://img.villagephotos.com/p...4.jpg
this is view of bottom of the airbox with the upper ccf air duct joining to it
http://img.villagephotos.com/p...5.jpg
view of bottom side of OEM VW airbox,
that golf ball sized dimple you saw in the carbon fiber duct is also in the airbox - between that dimple and the little extension tube that goes into the fitting on the fender wall, the upper duct really doesn't need any fastners to hold it to the airbox
http://img.villagephotos.com/p...6.jpg
this is a view of the airbox where the stock snorkel joins it and the ccf upper duct covers - the yellow tape, just to the inside edge of the area outlined is what i cut out or the opening i created for unrestricted air flow
http://img.villagephotos.com/p...pgand
this is a view of the upper duct by itself
http://img.villagephotos.com/p...8.jpg
and for comparison purposes, here is pix of the stock Vw snorkel and the CCF upper air duct side by side
the snorkel, at it's front end is approx 2.75 X1.1"
http://img.villagephotos.com/p...k.jpg
the cross section on the CCF air duct, at it's narrowest, just where it joins the airbox is (from memory) 4.5" X 2.75" which is far larger than even a 3.5" round CAI inlet tube
at it's front end is approx 4.95 X 4.5"
Modified by larryccf1 at 1:54 AM 11-17-2004
Modified by larryccf1 at 1:58 AM 11-17-2004
Modified by larryccf1 at 6:51 PM 11-17-2004
Modified by larryccf1 at 7:02 PM 11-17-2004
Modified by larryccf1 at 7:05 PM 11-17-2004
Modified by larryccf1 at 7:28 PM 11-17-2004
Modified by larryccf1 at 8:08 PM 11-17-2004
