1 - 1 of 1 Posts
So I plan on swapping an ALH into an older ce2 car using a plug and play harness from stancedubs. The issue with using my current engine harness is that I have a pre 2002 ALH harness where the glow plug relay was part of the body harness and not the engine harness. Can I simply just swap over to a newer 2002+ ALH harness when I do the swap or will this cause issues with the ECU or anything? Does the ECU care where the glow plug relay is?
1 - 1 of 1 Posts
