Hello , need a bit of help. I am in the process of swapping a TDI into my 93 passat wagon. As I was running wire to the relay box I noticed a loose wire , terminal still connected. The wire goes to the Anti Theft Module , it is Red/green , one of the 2 larger gauge wires coming from the module. On the module side this is one of the wires used to disable the alarm , by splicing the Red/Black and Red/Green together. Red/black should run out to the starter . Question where does the Red/Green go?
Thanks
Thanks
