OK so I just picked up this gti, w/ GIAC chip
pretty nice, runs gr8,
but it has a few little qwerks.
The CEL came on shortly after purchasing it which was alittle worrysome.
So I had it checked at autozone, and it came back with this
p1582
Definition:
idle adaptation at limit
explanation: rich air/fuel fatio, check fuel pressure/injectors
probably causes:
1check intake system for vac leaks
2canister purge solenoid stuck open
3 failed maf sensor.
NOW this actually sounds about right because the guy told me about
a crack in the intake elbow, which he thought was causing the idle to lope up/down.
I just wanted to post up here and see what you guys think,
as I have read that you can't quite trust what the autozone diagnostics tell u.
So yeah, what i KNOW,
throwing CEL p1582, and it's got a crack in the intake elbow..
Modified by Tad3d at 1:55 PM 7-16-2008
p1582
Definition:
probably causes:
