When I bought my car, I set up the digital cockpit as follows, and it's been this way for the entire year:
However, I decided the other day to just try putting the map in the center instead of the range. When I used the left/right buttons on the right side of the steering wheel to scroll through the options for the center, the navigation option originally started as a compass with the image of a car in the center of it. Then, like other options for the center, I could then press the up/down buttons on the right side of the steering wheel to scroll through the various sub options and select one by hitting ok. This is how I set the map in the center; it was originally a compass, and then I pressed up/down and scrolled down to "Map Display" or something like that and that put the map in the center of the cluster:
However, I decided I didn't like it and wanted to go back to the range in the center just as before. Simple, right? Well now I have two problems:
1) Once you are in map display as shown above, there seems to be absolutely no way to back out of it to the navigation sub-menu (where I can go back to compass or whatever other options were there originally); pressing the up/down buttons only zooms in and out of the map, it doesn't back you out to the sub menus, and pressing OK only toggles on/off the auto zoom feature. I've tried everything to back out of map display to get back to the sub menu, long press on ok, fooled around with the three different views, tried to scroll left and right through the other menus (driving data, phone, audio, etc.) and do any sorcery I could to get back to the navigation sub menu - anything I could do to get back to the sub menu structure for navigation and nothing works.
So then I was like well screw it, I didn't really care about going back to the sub menu anyway because I was just going to go back to the range display anyway. So I did that, but now...
2) Whenever I start the car, it initially displays the range in the center, but as soon as navigation starts, it replaces it with the stupid map display again. I have to manually scroll left/right back to range, and even when I first land on range and hit OK to for sure set it as my selection, the next time I start the car, same thing - starts with range, gets replaced with map display.
I think #2 is somehow caused by the fact I can't get back to the sub menu in #1 to set it back to the default compass option, so I think the car just automatically assumes that as long as I have the nav map display set under the nav option, that that's what I want in the center. This is pretty dumb because if I wanted that, I'd leave the car on it instead of switching over to range. Basically once I tried the map display option, I'm now forever stuck with it.
Any ideas how to get back to the navigation sub menu, up one level from selecting the map display option?
