41 - 60 of 99 Posts
I have successfully encoded the flashing of comfort turn signal.
I have a MY11 Golf MKVI purchased in February 2011, made after week 45, with European specifications, and through the VCDS (first with the 10.63 and after with the 11 beta) adapted the channel for 4 flashes and recorded (without errors) and did not change (although the scan appeared to the value 4 instead of 3).
Yesterday, through the FIS (I have factory-installed premium FIS), turn off the flashing of comfort turn signal and I went to turn on ..... and finally it works!
Now I have 4 intermittent flashes.
I hope that helps
Well, you inspired me to try again on my MY11 NA Golf TDI, but no luck.
What is FIS? Is that the same as the MFI?
Can you post an autoscan?
What happens if you try to change the number of flashes to another value -- does it take it immediately, or do you have to cycle the engine multiple times?
HOLY CRAP I GOT IT TO WORK
1. Change the number of flashes to the desired number. Close out VCDS.
2. On the MFI, Navigate to Settings --> Light & Vision --> Factory Setting
3. At the prompt "Set to factory settings for lights & vision?", select OK.
4. Marvel in amazement as the turn signal magically flashes 1, 2, 4, or 5 (yes 5) times.
No more, uh, tired left index finger for me! :beer:
I have a 2011 Golf TDI, North American, build date 7/2010.
Here's my autoscan, not that it's likely that relevant:
Code:
VCDS Version: Release 10.6.3 (x64)
Data version: 20101206
Thursday,17,February,2011,17:44:06:55943
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 55 56 62 72
          77
VIN: WVWNM7AJ5BW041198
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 906 019 DA    HW: 03L 906 019 DA
   Component: R4 2,0L EDC G000SG  7271
   Revision: 12H08---    Serial number:
   Coding: 0050072
   Shop #: WSC 01357 011 00200
   VCID: 6DFF1E2D0D17
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   Coding: 114B400C492600FB880C02ED92210042B70000
   VCID: 74C90B496E3D
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ASAM Dataset: EV_Climatic A01005
   ROD: EV_Climatic_VW36.rod
   VCID: 75CF364D6547
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 L    HW: 1K0 937 087 L
   Component: BCM PQ35  H   104 0615
   Revision: 00104 AE
   Coding: 6D180A3A80252AC40088008574008D04402D1F86534D8560648020200040
   VCID: 3A55E5710CD9
   Part No: 1K1 955 119 F
   Component: Wischer 23061  21  0512
   Coding: 009795
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R00JPHL
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   VCID: 3957FA7D09DF
   Seat occupied recognition:
   Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--00058E2J00
   Driver's Airbag Crash Sensor:
   Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME11213354ZZZD
   Passenger Side Airbag Crash Sensor:
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME542B2154ZZZS
   Driver's Rear Airbag Crash Sensor:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME12036526ZZZG
   Passenger's Rear Airbag Crash Sensor:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME26046467ZZZR
   Driver's Front Airbag Crash Sensor:
   Component: F.Sens.Fahr  --- ----
   Serial number: 35527SME06070323ZZZ/
   Passenger's Front Airbag Crash Sensor:
   Component: F.Sens.Beif  --- ----
   Serial number: 35627SME2E0E5022ZZZG
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
   Component: KOMBI         H03 0406
   Serial number: 00000000000000
   Coding: 270F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 2F43C425C79B
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 0602
   Revision:   H27       Serial number: 260610F2001345
   Coding: E9817F0610161200000002
   VCID: EDFF9E2D8D17
Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223R9BHR06
   Coding: 0000002
   VCID: FEDDA961D071
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0406
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EAF59531BCF9
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Component: SG EXT.PLAYER H13 0111
   Revision: A1001003    Serial number: 7668227646
   Coding: 010000
   VCID: 27732C05EF6B
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2113
   Coding: 0001204
   VCID: 3147C25DD1AF
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   VCID: 3147C25DD1AF
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06
   Revision: --------    Serial number: BP218109093456
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1_VW36.rod
   VCID: E7F3EC05AFEB
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Component: Tuer-SG         009 2139
   Coding: 0001204
   VCID: 3449CB492EBD
Address 55: Xenon Range        Labels: 5M0-907-357-A.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1446940
   VCID: 3449CB492EBD
   Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000022
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H13 0043
   Revision: -----26S    Serial number: VWZ4Z7K1147551
   Coding: 0101000001
   VCID: 61E7721DC1CF
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Component: Tuer-SG         007 2101
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 3449CB492EBD
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0001168
   VCID: 354FF64D25C7
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668223608
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA_VW36.rod
   VCID: 3245CD51D4A9
End   ---------------------------------------------------------------------
Code:
Chassis Type: 7N0
          77
   Coding: 0050072
   VCID: 6DFF1E2D0D17
   Revision: 00H30001
   VCID: 74C90B496E3D
   Revision: 00009001
   Coding: 0000001002
   VCID: 75CF364D6547
   Revision: 00104 AE
   VCID: 3A55E5710CD9
   Coding: 009795
   Coding: 00003031
   VCID: 3957FA7D09DF
Cannot be reached
   Coding: 270F01
   VCID: 2F43C425C79B
   VCID: EDFF9E2D8D17
   Coding: 0000002
   VCID: FEDDA961D071
   Coding: 000000
   VCID: EAF59531BCF9
   Coding: 010000
   VCID: 27732C05EF6B
   Coding: 0001204
   VCID: 3147C25DD1AF
   Revision: 00H17000
   VCID: 3147C25DD1AF
   VCID: E7F3EC05AFEB
   Coding: 0001204
   VCID: 3449CB492EBD
   Coding: 1446940
   VCID: 3449CB492EBD
   Coding: 00000022
   Coding: 00000022
   Coding: 0101000001
   VCID: 61E7721DC1CF
   Coding: 0001168
   VCID: 3449CB492EBD
   Coding: 0001168
   VCID: 354FF64D25C7
   ROD: UHVNA_VW36.rod
   VCID: 3245CD51D4A9
Oh snap! Im going to go out and try this ASAP.
Vendor
Hi! This sounds like good news. Do the 2011 clusters have the menu like this "Comfort light"?
http://i778.photobucket.com/albums/yy64/Dana_at_Ross-Tech/Cluster/Complete/DSC02322.jpg
http://i778.photobucket.com/albums/yy64/Dana_at_Ross-Tech/Cluster/Complete/DSC02301.jpg
If the setup is different and this is the fix, please post a picture and I'll link it from the sticky.
Yes, I can confirm that my car looks similar to that.
Here is a more detailed version of the procedure that I followed, with pictures from my MFI:
AFTER changing the desired # of flashes using VCDS, disconnect the cable and cycle the ignition for good measure. (I did not start the engine, as others have reported.) Re-insert the key to the ACC position if you haven't already.
Then, on the dashboard MFI, navigate to "Settings":
Click "Lights & Vision" (highlighted above). This takes you to the following submenu (your options may be different; e.g., "Coming home" is not enabled by default):
Click "Factory setting" (highlighted above). This takes you to this submenu:
Click "OK" (highlighted). This seemingly does nothing, and takes you back up to the parent menu.
Once you have done this, the # of flashes you set in VCDS will work correctly. From what I could tell, nothing else is changed -- I had guessed that I would have to re-enable "Coming home", for example, but it left all that stuff alone.
Obviously, this additional step is only required for some 2011s.
Just my observations:
I've noticed sporadic reports of people having had success by flashing it multiple times, turning the engine off and on, etc. In my experience with embedded controllers and the like, sometimes they can be a little "squirrelly", and the VAG ECU seems to be no different. With VAGCOM, I've found you have to very deliberate/slow, changing one thing at a time, disconnect and power cycle between each change, and so forth. If you go too fast, you can get unpredictable results, and simply cycling the ignition or re-flashing a code fixes it. I bet the folks who have had success by flashing multiple times, etc. basically took advantage of a bit of instability in the PIC and effected a reset without knowing it, perhaps.
Here's what really intrigues me though. I wonder what other settings can be enabled on the mk6 using this general procedure (VCDS + MFI reset). There are many interesting-looking settings I have found in VCDS that don't seem to do anything when I toggle them, so I switched them back -- but I wonder if I should try these settings in combination with the MFI reset as well.....
phatz314, U da Man!
Thank you, thank you, thank you!!!
This has been a source of frustration for while now.
All I had to do to get this to work was reset lights to factory settings since I had already coded VCDS to a value of 5, many months ago.
This is on a 2011 GTI.
phatz314, U da Man!
Awesome, this is the first confirmation I've gotten that this works on another vehicle! :thumbup:
Still thinking it's a bug with the rev 0615 BCM, but it sounds like this is a workaround for at least some vehicles.
Vendor
I agree, that factory default cluster options seem to resolve buggy problems after coding on the 2010 cars too.
i.e. If you change cluster coding and the units (speed/time/temp) don't display properly until the car is put to sleep or the defaults are selected.
I changed the link to that post, thanks for the pictures and detailed explanation!
  • Comfort Turn signals
    Found in Adaptation. From the drop down list, choose the number of flashes and Save.
Note: 2011 owners may want to see: This thread
On another note, and possibly another thread, do your fogs as cornering lights work as I described here?:
  • Cornering Lights via Front Fog Lights active
    Found in Coding, Long Coding helper
Notes: The lights may work under the following conditions:
  1. The headlights must be turned on and the steering wheel must be in the turning direction.
  2. Headlights on, fogs off, turn signal on in the turning direction. Also see Byte 17, Adaptive Light/Cornering Light Variant. This seems to control the fogs as cornering lights with turn signal.
Some owners have reported that the mentioned Byte 17 coding doesn't alter the turn signal operation, but I don't recall if this is with Halogen and Xenon cars or not?
Yes, I just checked, and my fogs-as-cornering-lights work as you described. And, I can confirm that they work the same as they did before this "mod".
My vehicle has xenons + the stock North American headlight switch.
So, explicitly speaking, if and only if the headlights are ON and the fogs are OFF, one single fog light will illuminate if I (1) engage the turn signal in that direction, or (2) turn the wheel in that direction. FWIW, the cornering light doesn't work if you just tap the turn signal stalk (i.e., comfort turn signals).
Thanks again phatz, I got the comfort turn signals to work with 5 blinks on my 2011 GTI using your method. Like dmichael, I already had it coded to 5 so all I had to do was reset to factory in the MFI. Using Xenons + Euro switch.
When I get home, I'm going to see if I can get the fogs as cornering lights to not come on with turn signals using the same method.
I attempted this on a my 2010 A3, if I set it and don't turn the car off, the setting sticks. I had set it to 5 blinks, now if I shut the car off and restart then it only flashes 3 times, even with the adaptation set for 5. I'm not seeing any way to do a Factory Reset from the menu. :-(
I did this on my 2011 JSW aka Golf Variant. It's manufactured 11/2010 and has the same Lights/Vision MFD as pictured above (but without the Coming Home option).
I did NOT have to reset the factory settings. I set it to 5, saved and it stayed, even after a few power cycles.
Interesting, maybe there was a bug and they cut in a fix. Mine was built 7/2010.
Just out of curiosity, what BCM version do you have, later than 0615?
Edit: oh I see you have a Jetta, that could be the difference
With the car ignition in ACCESSORY mode I made the change from 3 to 5 signals and it worked. I didn't have to cycle the key or anything.
All I did was reprogram via vag-com, reset to factory defaults the lighting options and bam it was done.
5 is perfect :laugh:
JSW = Golf.
I'd note that I had previously set my cluster to UK to turn off those annoying seat belt and door open chimes. I'm not sure if this had anything to do without having to do factory default, or if later manufacturing date has this bug fixed.
EDIT:
HTML:
   Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
   Component: BCM PQ35 B    011 0035
   Revision: BG011001
   Coding: 2D380E3F902F3EC4008800816000000401000086535D8560648020000040
   Component: KOMBI         H23 0204
   Revision: X0023007    Serial number:
   Coding: 270F01
41 - 60 of 99 Posts
