1 - 20 of 20 Posts
welp,i wanna change the trans fluid in my girlfriends 94 jetta 3 gl...except i dont know anything about vw's...is it the same as any other car...just take bolts outta trans pan let it drain,change filter,put pan back up and then add reccomend amount of trans fluid???
Re: (red94jetta)
how often are you supposed to change your tranny fluid?
Re: (duke_seb)
Quote, originally posted by duke_seb »
your not supposed to change it ever according to vw
but often times it needs it.
Re: (JettaAE)
is it the tranny fluid the reason that when i push in the clutch and shift the car kinda jolts a little??
Re: (duke_seb)
no...it's because you don't know how to shift....
Re: (JettaAE)
Quote, originally posted by JettaAE »
totally wrong dude! your suppose to change the fluid like any other transmission... its all about marketing for a low maitenance transmission... check out this link...
i suffered like the rest in this link... my transmission failed at 90ks because the fluid was never replaced... here are some pics of the fluid... exactly 88283 miles of usage on the fluid... i changed the fluid, but the tranny was still slipping and gave at 90952 miles... i had to get another used tranny cause the one i had in my jetta, the internals melted and it was not rebuildable, i spent $3200 to get it rebuilt... i knew i should of done a manual swap, but i havent thought of it at the time, i was just pissed off because of not driving my car for 3 months http://****************.com/smile/emthdown.gif
the tranny filter, you can see the black is all the crap that the tranny suffered from... inside the filter, theres alot of metal shavings i never seen before
another shot of the filter...
heres the fluid, all black, if you were to feel the fluid, felt like your hand was in wet sand... as you can see in this pic, the bubbles aren't really bubbles, its metal particles...
Heads-up: VW "Lifetime" auto transmission fluid (baloney!!!) <- i highly suggest you people check this link out!
Re: (DaFabolous2.0)
Quote, originally posted by DaFabolous2.0 »
totally wrong dude!
did u just skip over the second part of what i wrote? i said according to vw you dont have to change it. and then i said it does often need it! REad the Whole reply next time instead of trying to make me look like an a$$ or like i dont know what i am talking about!
Re: (sphipps)
Quote, originally posted by sphipps »
i knew youd be an a$$ and no its not because i dont know how to shift....Its only gradually started to get worse
Re: (JettaAE)
chill dude, i was at school, i just skimmed through it
...sorry if you're offended by it...
Discussion Starter · #18 ·
yea the tranny fluid in the jetta looks a little brown...burnt i guess...figure change that n filter now before somethin bad happens...thanks for the help!
Re: (JettaAE)
your not supposed to change it ever according to vw...
Yeah, this from the same rocket scientists that claim that it's acceptable for a car to burn 1 qt. of oil every thousand miles...
Who would you believe?
1 - 20 of 20 Posts
