Re: Changing bulbs in side markers on jetta?? Search is down (wolfs18t)
ok it you mean the ones on your side front quarter panel that are real small do this, it is straight from the repair book for our cars. OK they break easy so be VERY gentle and careful. One side has a spring clip the other mounting pins. you have to find out which side the spring clips are on it is difficult to do it says. Pry with a plastic tool and carefully press the light towards the side of the spring clip and remove. So you will either press forwards or backwards depending on which side has the clip. Then pull rubber holder and push fit bulb from bulb housing. Remove bulb by pulling holder and replace if ness. Then just reverse it. to get it back in. if this dont help ill get you more.
