Re: changing from one tire size to another (timshier)
I did this exact tire change. I went from the 65 series Conti CH95 tires that came from the factory to Yokohama AVS dB in the 60 series size you're considering.
The difference in handling was night and day! The turn-in was tremendously sharper, and stability in all handling maneuvers increased dramatically. Ride quality did not suffer one bit.
And there's a bonus: The 60 series profile sticks out over the sides of the wheels more than the 65 series rubber -- handy built-in rim protection!
Note that this tire "upgrade" will result in an ever so slight increase in circumference. That means a slight drop in the speedometer reading. So, you'll be going 1 or 2 MPH faster than the speedo actually says. Something to keep in mind if you like to keep your speed below a certain point, in order to discourage the interest of cops. (I try and keep my car at 79 MPH in known cop-monitored areas, as that seems to be the breaking point with CT state troopers.)
Rain traction can be hampered by a lower profile tire, but in this particular change, there is negligible difference. If rain traction is a priority for you, I suggest that you review the Tire Rack product ratings for tires that excel in the rain. I can tell you that Yokohama's AVS dB is an "ultra-high-performance, all-weather tire" (Tire Rack's words) that has wet traction at the top of the pack. I am constantly impressed by these tires. Even when they do break free in the rain, they don't become dangerous.
Modified by chrishart1 at 10:36 AM 7-20-2003
